| Home > Wanted > Hi boost actuator spring or possibly actuator. | |||||||
![]() 4633 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
2nd Apr, 2009 at 07:01:54pm
I know it's a long shot, but has anybody got an actuator spring to fit the aftermarket billet alloy actuators ? I need something around 15-17psi.
Edited by Turbo Phil on 2nd Apr, 2009. |
![]() 84 Posts Member #: 5645 Advanced Member middlesex ( near heathrow ) |
2nd Apr, 2009 at 07:06:54pm
something like this any good phil
Don't go slow !!! Go Turbo :)))))) |
2nd Apr, 2009 at 09:51:28pm
That's the type i have yes. So i either need the spring to put in mine or a new actuator & sell mine.
2nd Apr, 2009 at 10:24:18pm
Wouldn't it be as easy as stretching the spring that's already there? :) On 13th Jul, 2012 Ben H said:
2nd Apr, 2009 at 10:39:49pm
Possibly, but how long will it hold its tension for ...... |
2nd Apr, 2009 at 11:04:27pm
I may have a spring in my bits box, I'll have a look tomorrow. Isambard Kingdom Brunel said:
3rd Apr, 2009 at 05:49:51am
Is it possible to pack the spring a little ?. |
![]() 861 Posts Member #: 951 Post Whore Bromsgrove |
3rd Apr, 2009 at 09:24:59am
I have an as new billet actuator from Avonbar,no longer needed.I ran this at 17psi ok.Would sell this for £45 posted. 'Where does the engine go?' |
3rd Apr, 2009 at 03:49:24pm
Why not just buy a standard 4x4 Sierra actuator? Available on ebay for pence.
3rd Apr, 2009 at 05:57:45pm
On 3rd Apr, 2009 Tom Fenton said:
Why not just buy a standard 4x4 Sierra actuator? Available on ebay for pence. What boost do they give Tom ? |
3rd Apr, 2009 at 06:08:06pm
Standard 4x4 boost was 12psi if I remember right, add some preload and I'd have thought 15psi is no problem.
3rd Apr, 2009 at 06:34:47pm
Cheers Tom. My current actuator will only give 8psi no matter how much preload i use, so i have to use a bleed valve to get it up to 20. |
3rd Apr, 2009 at 10:33:24pm
I've got two forge springs, ones is about 15 psi and the other is about 20 psi, I think, the only way I could measure them was to connect the actuator up a bike pump and increase the "boost" and watch when they started to open which isn't the most scientific method. Isambard Kingdom Brunel said:
