| Home > Help Needed / General Tech Chat > left hand engine steady | |||||||
298 Posts Member #: 1357 Senior Member telford,shropshire |
2nd Apr, 2009 at 11:09:24pm
hi chaps
'always keep a spare shot for a stray bird' |
3rd Apr, 2009 at 09:11:14am
Should be exactly the same plate mate, bit confused to what you mean |
3rd Apr, 2009 at 09:13:43am
You can barely see the bracket at the right of the master cylinders here.
3rd Apr, 2009 at 09:41:41am
The steady wont come with a plate to replace the master cyclinder mounting plate. I think you are getting confused, do you mean LH as in passenger side? |
3rd Apr, 2009 at 09:57:14am
LH and RH are useless terms as it depends on where you are viewing the car from. Some would argue that left and right should always refere to when viewing from the driving position, but this is just confusing when looking under the bonnet.
3rd Apr, 2009 at 10:10:17am
Sorry that's what i meant, you should always use the terms as if you were driving the car. Threfore the steady he is refering to should be the one that bolts to the thermostat which is why i'm confused. |
3rd Apr, 2009 at 10:36:43am
If you are fitting a steady to the thermostat end of the engine then you will need to remove the blanking plate that covers the spare holes on the cross member.
3rd Apr, 2009 at 11:09:22am
sorry for the confusion guys, ok ive been looking at an ultimate steady from wood and pickett that fits to the off side (drivers side) of the engine which replaces the original.
3rd Apr, 2009 at 11:23:30am
The only one i can see they do bolts on the LH side to the water pump. http://www.woodandpickett.com/shop/classic...le-listing/160/ ?? |
3rd Apr, 2009 at 07:10:37pm
im confused it turns out then!! i thought this steady was for the left hand side when facing the engine. my bad
