| Home > Help Needed / General Tech Chat > Turbo gearbox numbers???? | |||||||
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
5th Apr, 2009 at 11:19:03am
hi, i had two gearboxes come with my engine one the original metro turbo box for the engine and the other i dont know what it came off. they look identical but have different numbers one is - A/BZ2 BC&M DAM5626, and the other is - A/BZ6 BC DAM5626. i want to rebuild one of these boxes along with the engine does anyone know which one is the original or if it matters which one i use? cheers |
5th Apr, 2009 at 04:24:14pm
a/bz1 bc dam 5626 ,is the no on my turbo box on my car haimesy ,i think it makes no difference to be honest .
5th Apr, 2009 at 04:41:44pm
thanks robert, im guessing that the DAM 5626 makes them compatible so im gonna start stripping the cleaner one of the two :) cheers. |
5th Apr, 2009 at 07:23:50pm
if you have a 3 bolt retainer box, id use that
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
6th Apr, 2009 at 05:05:28am
the first motion transfer casing bearings bigger on the turbo box, also the final drives 3.1:1 , i dont think the bearing makes a real difference, possibly BL being strange
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
6th Apr, 2009 at 07:44:48am
Turbo final drive is actually 3.2:1, peculiar to the turbo boxes only, and different to the 3.105 final drives as fitted to later minis.
