Home > Show Us Yours! > New cylinder head..
giallofly
Member #: 164
The Stig..
Newport Pagnell
We have all seen pictures of modded heads before so I won't bore you with a picture of every angle.
Turbophil of this forum as many of you know grinds a few heads, for this season he has done me a bespoke head for my Challenge Metro. It needed it to be a certain specification due to the strict rules.
Phil has come up with this little gem, extactly to spec, chamber CC, shape, valve size etc. Even the exhaust and inlet guides are a different design for flow and heat absorbtion. The finish of the ports and chambers are as good as big name.
I have taken the task of finishing the head with it final skim, 11 stud drilling, valve lapping, paint and assembly.
I am very pleased with this head, another established forum member has seen it up close and it got it's approval.
He has showed his passion for getting it right, not just a "get it done and the grab money" attitude with lots of thought and reason for a particular angle or shape of grind.
Remember it is not only a cylinder head that wins races but I am sure we are heading the right direction with this one.
JF.
Edited by giallofly on 14th Apr, 2009.
PaulH
Member #: 2340
Dublin Ireland
Good Man Phil Keep up the good Work,
*wink*
On 17th Feb, 2009 Rob H said:
AND its red!
Ben H
Member #: 184
Melton Mowbray, Pie Country
That is a very novel way of getting 16v.
http://www.twin-turbo.co.uk
AH!!, you casn't beet the good old dial gauge shot to big the job up can you,lol.
looking good,
Definately hiding something!!!!!
I've seen phil's work, good job.
Edited by wil_h on 10th Apr, 2009.
tadge44
Member #: 2500
Buckinghamshire
I,m driving with one of Phils heads -you wont be disappointed I can tell you.
looks nice and smart
slightly OT, why do nearly all perfomance 940's i see be the early shape rather than the 'flat top' casting, is there any noticable difference between the 940 castings?
*edit* Jon, you love conrod bolts too then?
Edited by joeybaby83 on 10th Apr, 2009.
The shape in the pic is the later head matey, its the early ones that have the flat machined area near the thermostat housing.
ah, i stand corrected, is there any difference?
According to Vizard the later ones with the cast in area have slightly better water cooling passages. In practise I don't think you'd tell the difference.
Why do I have the feeling that Phil's done something trick with either the guides, ports or chambers.
What you hiding?
PS. I've still got your engine & head.
True, very true *happy*
*wink* *wink*
Cheers guys ! Lets hope it delivers the goods on the track.
giallofly
Member #: 164
The Stig..
Newport Pagnell
The ports are very good indeed and the chambers could be different to most turbo applications???..
Yes, Rob, not forgotten...
JF
love the nuts on the rocker adjusters.. nice head..
hario
Member #: 2885
DTI gauge for tappet adjustment! Didnt think of that one.
giallofly
Member #: 164
The Stig..
Newport Pagnell
The DTI is check valve lift. well worth checking to get every bit of lift.
JF.
