| Home > General Chat > Indicator relay for LED bulbs | |||||||
13th Apr, 2009 at 12:26:32pm
Just put 2 led bulbs in my volvo's rear clusters, and now they fast like a bulb has gone out.
559 Posts Member #: 2775 Post Whore Aberdeen |
13th Apr, 2009 at 01:20:35pm
I thought the leds from the likes of helfrauds etc that replace a normal bulb had a resistor or a circuit board built into them just for this reason. |
13th Apr, 2009 at 02:02:22pm
im using some cheapish bulbs bought from hong kong, so prob not got that :( "Turbo's make torque, and torque makes fun"
19 Posts Member #: 4217 Member Scotland |
13th Apr, 2009 at 03:17:29pm
Just modify a GM one
13th Apr, 2009 at 07:16:21pm
I noticed this when I had the wing-mirror of my folks civic disconnected. The wing-mirror had an LED bulb and the lights still flashed at normal speed when it was disconnected. I assumed it was because the LED was a much lower current draw than a standard bulb and therefore had little impact on the time taken to energise the coil in the relay.
Gary's description is best |
13th Apr, 2009 at 07:23:10pm
Well, surely all you need is a resistor to make the flasher think there is still a bulb fitted? On 17th Nov, 2014 Tom Fenton said:
13th Apr, 2009 at 07:49:07pm
good tip ken, but tbh id like to just buy one and fit it lol, lots readily available on ebay for about £15, but i suspect they can be got for less fromt he motorfactors once i figure out what model have them.
976 Posts Member #: 3228 Post Whore North of the Netherlands |
14th Apr, 2009 at 08:32:26pm
I opened the relay, took out the capacitor, replaced it with a 'bigger' one.
Dazed and Confused.... |
14th Apr, 2009 at 08:57:47pm
most modern flasher units will keep a constant flash rate over a very wide current loading, if you pop the lid off one you will see an IC (probably an 8 pin package) and circuit chances are this type will be ok with the LED bulbs.
14th Apr, 2009 at 09:19:19pm
whats a relay doing with an intercooler!!
