| Home > Introduce Yourself > breathers | |||||||
4 Posts Member #: 5816 Junior Member |
13th Apr, 2009 at 08:02:28pm
hi all.ive just run in my first turbo engine but im having a bit of troble with me gaskets.the gasket between the gesrbox and block has poped out and split,also the timming one has as well when i gave it a bit of a blast on saturday.i was told that it could be the breathers ,so i checked them and they were a snotty yellowy watery mess inside.ive got 2 little k.n filters on them just breathing to air one on timming cover and one on the fly wheel housing .do you guys think that it could be they problem and is it caused by to much cold air coming from my evo bonnet. |
869 Posts Member #: 2443 Post Whore Cheshire |
13th Apr, 2009 at 08:10:20pm
Sounds like you have excessive pressure in the crankcase. I would start by ensuring the breathers are completely clear as they certainly wont be helping. Would also be worth doing a compression test to ensure the rings have bedded in properly and that your not just experiencing excessive blow by from one or more of the cylinders. |
13th Apr, 2009 at 08:23:07pm
thanks for reply im sure the rings are fine,i did the test on the day what do you no about plumbing them in or have i done it write. |
13th Apr, 2009 at 08:44:07pm
Having two K&N breathers filters is perfectly acceptable as long as they are perfectly clear. may be worth taking the breathers off the engine and make sure the seperators are clear, wash them out with some petrol you will probably be amazed at how much crap comes out of them. |
13th Apr, 2009 at 08:51:07pm
good stuff what do u think caused it to milk up, also have a lot in the rocker cover .is is likely to be my bonnet as it has 2 big holes in the top. |
13th Apr, 2009 at 09:08:20pm
water in the oil causes this.
13th Apr, 2009 at 09:15:26pm
yeah could be but its not useing water |
14th Apr, 2009 at 12:12:32pm
I would put it down to short runsand condensation. get a milky film on the inside of my rocker cover at times but a nice run would soon clear it up. Own the day
