Home > Technical Chat > How You Wire Up Your Turbo?
Zeemax Power
Member #: 393
Oulton Park
I have a 1.3i mini and have brought an MG Metro Carb and Turbo and am changing it from injection to carb and want to know how you do away with the ECU. and what wires you need and where you take the wires from and to. To wire it
ITS A MINI ADVENTURE
http://www.Zeemax.com
nutter driver
Member #: 47
Not very sunny swanage
have a good read of the how to section of this board, most, if not all the informatin you require will be in there.
generally speaking most people throw the ecu away and run exactly the same as a n/a car in terms of dizzy, carb etc, no ecu.
Pete
