Home > For Sale > SPI tank, Lines, and Pump
I have an SPI tank with the pump, and also the lines that run the full length underneath the car, up into the engine bay including the return line.
Its all in good condition but i will give the tank a clean and a spray for the buyer.
£40
Cheers for looking, James.
I'll have it, but I'm not coming to Devon to collect it.
Do you come up to the Midlands at all?
uhmm i might be going to york soonish? but not really sure when...
failing that...Riv Run? Avon?
I dont mind holding onto it.
We will probably be going to Himley Hall next month.
Definately going Avon and MITP.
If you can sell it to someone else before then no problem, otherwise I'll remind you nearer the events.
i'll hold it for you Paul. Im in no rush.
Doubt i'll be going to Himley but i might be able to make a detour when i go to York.
I'll let you know.
c2_mad
Member #: 4215
if by anychance the other chap changes his mind i will have it off you the same day.
