Home > Help Needed / General Tech Chat > How far to push the primary gear oil seal in.
I don't intend taking the clutch apart again any time soon so thought I'd replace the primary gear oil seal as the primary gear had to come out to get a new shim.
How far should the face of the seal (clutch side) protrude or recess into the transfer casing?
Thanks
James
hi james, make it "nearly"...... flush with the face,
make sure you dont damage the new seal with the primary gear splines by placing sone tape over them.
Thanks Steve
If you are going to be doing it a few times, the tool is an amazingly easy piece of kit to use and takes all the worry about damaging the seal and correct straight fitting, out of the task. The tool presses it in about 0.5 to 1mm just below the face of the case
Which Tool?
Alex1340
Member #: 111
Loughborough
these like a cup type thing you can push the oil seal in with has a thread the screw in from what I remmember. Handy bit of kit.
This one?
http://www.minispares.com/Product.aspx?ty=pb&pid=36654
miniminor63
Member #: 672
The oversills police
Oslo, Norway
yes
