| Home > General Chat > TPS | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
15th Apr, 2009 at 09:43:54am
hi.
15th Apr, 2009 at 12:56:26pm
You need to measure the resistance between the pins. Typically between the two outer pins you will get 5k ot 10k ohms, whatever the pisition of the spindle. Between an outer pin and the middle pin will change from around 0ohms to the ohms measured between the outer two pins as you sweep the spindle.
http://www.twin-turbo.co.uk
15th Apr, 2009 at 03:50:09pm
my tps does not have a 12v it would explode if it did. it runs on 5v feed from my MJ |
15th Apr, 2009 at 04:51:07pm
You are correct the feed should be out of the MJ and be 5v. The principal is correct though.
784 Posts Member #: 912 Post Whore North Yorkshire |
15th Apr, 2009 at 11:43:46pm
Here's a link to Auotlabs which I created to find out how to wire my TPS.
Edited by Si P on 15th Apr, 2009. I drill holes in everything..! |
