| Home > Help Needed / General Tech Chat > T2 oil drain | |||||||
25th Oct, 2004 at 03:02:49pm
hey guys |
25th Oct, 2004 at 03:56:08pm
Jim and me both have a 16mm alloy pipe weled into the gearbox casing. A nice solution, but a little 'late in the day' for you!
![]() 1128 Posts Member #: 142 Post Whore Winchester |
25th Oct, 2004 at 04:47:37pm
could you grind down a flat section on the back of the gearbox drill a hole the same size as the drain hole in the block, then drill and tap bolt holes either side of it, also the the same size and spacing as the ones in the block then make a gasket and mount the original oil drain there?
25th Oct, 2004 at 05:06:01pm
I think you could, but you would need to strip the gearbox todo this or you would get crap in there, so you may as well weld it and do the job right 1st time.
25th Oct, 2004 at 07:31:57pm
i was thinking about (you may not want to read this) taking off the gearbox, shielding everything with sticky back plastic and cornflake packets, drilling and tapping a hole putting in something like an aeroquip bulkhead connection and running a hose up to the turbo, bolting it back together and hoping no swarf was in my box
26th Oct, 2004 at 09:46:52am
The page does not exist
26th Oct, 2004 at 06:23:45pm
I got a mate to knock up a 90 degree bend out of 16mm pipe and welded it onto the existing plate, then reused the origional green bit of silicon tube, not really tested yet tho.... |
29th Oct, 2004 at 06:47:55pm
try this http://www.netsnapshot.com/users/13975/ima...Bs_13975_67.jpg
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
29th Oct, 2004 at 07:05:50pm
That's not working either Mr Rizzadini.
30th Oct, 2004 at 12:13:02am
ah bugger it, it was crap anyway |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
4th Nov, 2004 at 05:56:51pm
we could supply and weld that on for you Nick. Its a box strip though. |
