Home > Help Needed / General Tech Chat > leaking calipers
MarkGTT
Member #: 1194
Shropshire.
Hi, are the metro turbo 4 pots prone to leaking??
not even used mine yet.. just been sat on the car (probably for well over a year now) and when bleeding the feckers they have started to leak from the bottom pistons.
Also does anyone know if i need 2 or 4 of these for the front set, and would it be wise to replace all or just the leaking ones?
http://www.minispares.com/Product.aspx?ty=...AIR%20KIT%204...
cheers, Mark.
luckily i jst happen to have one of those kits sitting here *wink*
that kit will do one whole caliper, it contains 4 seals, 4 dust seals and 4 dust seal retainers.
i dont think the calipers are particuarly prone to leaks, check the pistons for marks/ rust pitting though.
Edited by Joe C on 15th Apr, 2009.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Never had to refurbish a set. I just dig around in the garage till I find a set and throw them on, most have been lying around in there for over a decade.
The only thing is The were all capped off filld with fluid.
Own the day
MarkGTT
Member #: 1194
Shropshire.
yeah.. mine weren’t until a few days ago, this could have been this issue.
