Home > Help Needed / General Tech Chat > manifold gasket
adam1330
Member #: 238
essex
anyone got any opinions on what manifold gasket is the "ONE" to use?
if so, what makes and part numbers please..
i ask this because i brought on but its different to the one i took off..
Nick
Member #: 154
Midlands
i use the one that comes in the payen head gaskets sets. it's got the steel rings round the exhaust ports.
T3Tone
Member #: 252
Sunny suffolk
Not sure on part numbers but the injection ones work fine and are a little cheaper than the metro turbo ones.
-MINI CLUBMAN 1380 TURBO-
if your having problems finding a metro turbo manifold gaskets in stock, then you can use the one from the injection mini also. It's not quite as good, but it's good to use as a backup. I'm using one at the moment on my mini, full boost 18 psi, no problems!
