Home > Technical Chat > day dream engine specs..
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
What specs would you guys go for if someone asked you to build them an engine?
Say you were looking at 130hp, 150 and 175 as options....
I'm just bored at work today!
Alex
AlexF
philc
Member #: 1346
bromsgrove
K series head conversion
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Ditto, with nice 4 bold mains, fully worked crank, custom cams and a carefully selected turbo. Plus one of these new verto clutches people are making on here.
On 7th Nov, 2008 Nic said:
naeJ
m
For 130bhp I would say.
Mildly modded head 35.7mm inlets
Cast pistons aiming for around 8.6:1 CPR
MG Metro/KC500/Kent 266 Cam
Cast Duplex Timing Setup
Grey clutch
Balanced bottom end
Intercooler
10-12psi
x-pin diff with 3.2FD
poss sc drops depending on usage of car
For 150bhp as above but
More head work
CPR around 8.2-8.4:1
Double grey clutch
Definately SC drops
Poss Avonbar PH2
Poss SC box depending on usage.
x-pin with 3.1/3.2FD
around 15psi
For 175bhp +
Fully Worked Head
18cc Forged Pistons (Omega/Accralite)
CPR between 8.0-8.4:1
Avonbar PH 2 Cam
Duplex Timing
Steel Flywheel
Double Grey/Double Verto
Balanced
SC Drops
SC Box
ATB Diff 2.9/3.1 Diff
Efficient Intercooler
18-20psi-ish
Edited by John on 16th Apr, 2009.
7 port with webers on a 1380, racey cam with of those loovvely sycquential dog boxes that cost 4 grand
Mr Joshua
Member #: 1954
Luton Bedfordshire
By a kit from MInispeed why try and re-invent the wheel!
Own the day
Wheres the fun in that!
Sam
Member #: 1686
Oxford
Are you haveing a giggle?
OMG Robert that's a big one
1460, KAD 16V, job done!
why stop at 175, when over 250 is cheap easy enough
How cheap and easy jim. Get more in depth.
Rick
Must admit if money was no object the 1460 kad would be top of my list. yes more power is acheavable but you carnt beat a 16v kad at 9k.
buy a kit from morspeed ...lol wait 24 year and no refund or engine.
73.5 bore alex and stroked crank
Carl S
Member #: 1761
Stalker
I'd pick up a Rover K series engine for 50 quid :)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Why?
AlexF
PaulH
Member #: 2340
Dublin Ireland
He obviously need an anchor for his new boat :-p
Why?
On 17th Feb, 2009 Rob H said:
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
But Paul they arn't even good at that!
Far too light!
Alex
AlexF
Carl S
Member #: 1761
Stalker
Well i would have said for free instead of 50 quid as i recently got given a K series engine :)
60k miles, weighs less than the A series, more power as standard, good fun to put in a mini i think. Far more cost effective than spending thousands of pounds on an engine that needs constant maintenance and a rebuild every ten minutes.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
No point in having a classic if you go down that route.
On 19th Jan, 2010 wil_h said:
Carl S
Member #: 1761
Stalker
Why?
Alex1340
Member #: 111
Loughborough
Get a 850 paint it RED get 300bhp, sell on ebay. Job done.
Rick
K1100 16v head,
18cc forged pistons pistons
worked A+ rods
modern GT ball bearing tubo
Good ECU (there all the same)
strong gearbox and clutch
Put all that together properly and do a good job of mapping it and you should see over 240bhp at 18psi and torque from 4250rpm through to 7000rpm
