Home > General Chat > what is the trick to soldering to old, blackened copper wiring?
We've all seen this wiring, where the plastic insulation has got too hot, or has got moisture in it - or whatever! Fact is, you have a wire you need to solder to and it is black. Even if i try fanning the wire out, scraping it, re-fanning it, re-scraping it, etc - it just never solders well.
So, what are tips or tricks that I don't know?
After cleaning it as best you can mechanically. dip it in flux paste - the stuff used for soldering central heating piping.
Make sure it's the "active" flux - in the UK a lot of the fluxes are useless (and most of the solder is lead free), all to do with water quality after you've soldered your plumbing - but the ones called "active" still do a reasonable job on wiring as you describe.
As Rod says: flux
There are a variety of electronic orientated fluxes out there as well as plumbing fluxes (which are slightly more common)
http://uk.rs-online.com/web/search/searchB...7763+4294953973
Don't ask me which flux to go for mind as it's been about 10 years since I worked in the labs and used this stuff.
Carl
Member #: 95
liverpool-on-sea
http://cgi.ebay.co.uk/100-NEW-SNAPLOCK-SCO...A1%7C240%3A1318
LOL!
Mr Joshua
Member #: 1954
Luton Bedfordshire
People people why make life hard for yourself, the easiest way bar far and this method removes the least amount of material possible.
DIP THE WIRE IN VINEGAR
Edited by Mr Joshua on 17th Apr, 2009.
Own the day
Vinegar... Hmmmmm.
just as a heads up - I would swap out the whole wire, but I can't get to it!
Hence I'm taking an easier approach.
I'm going to try vinegar immersion, and then adding flux.
I heard the vinegar thing just this morning for cleaning coroded things up, will be interested to hear how effective it is.
greymini78
Member #: 2408
surrey / ewell area.
Very effective ....
i tell u what else is good .. a certain brand of fizzy drink that has stupid christmas commercials. We used to clean our lorry tailgates with it.
On 17th Apr, 2009 greymini78 said:
Very effective ....
Stella?
Very effective ....
Stella?
PaulH
Member #: 2340
Dublin Ireland
Ya must me stella last time I lowered a few stella It cleaned my tailgate right out an all ............
On 17th Feb, 2009 Rob H said:
So where does the Fluxcapasitator come into the picture?
DD_Racing
Member #: 3013
Epsom Surrey
old crappy burnt out wiring i dont bother!!! just renew it all!!
This is in a 3ph motor I'll be using for a phase converter. I don't want to go to the hassle of opening it up.
h4887
Member #: 2404
Braintree, Essex
Unfortunately any flux which can cope with that level of oxidation will eventually corrode right through the wire, unless it can immediately be thoroughly washed in hot water which tends to be difficult on a car. In any case capillary action will have drawn it well inside the sleeving, so it's only a matter of time.
Geoff
Lance Link
Member #: 1174
Sunny Southern California, USA
You have to remove the corrosion. Without doing that first, you will always get a cold soldering joint.
I've used a sand paper 'flap wheel' with great success. Just flatten out the wire strands and go at it with the sanding wheel.
This is the flap wheel I used... http://www.dremel.com/en-us/AttachmentsAnd...il.aspx?pid=503
61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
www.motorlust.com - The Online Magazine for Car Guys Like Us
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Stella! A few cans...you can beat the shit out of the copper!
On 19th Jan, 2010 wil_h said:
NO NO NO!!!
stella contains aluminium,lots of it, thats what make chaves go mental on it, the ally will react with the copper and detroy it, just like the memorys of beating the missus within an inch of her life!
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
do the coppers not get fed up of getting bet up by chaves ruining their wiring with steluminium?
what wrong with black coppers?
racialist!
