| Home > Help Needed / General Tech Chat > megajolt setup on RR | |||||||
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
17th Apr, 2009 at 09:44:44am
Went to Mech Motor sport in Cheltenham yesterday to set the car up.Fuelling now ok,was far too weak on boost.However could not set up ignition timing.I have an AFRacing mjlj with v3 software from about 2 years ago.The problem is that we could not reset timing other than by changing a site individually and then uploading it.This is very time consuming and damaging if you're getting detonation.So how can I reset timing 'on the fly'to overcome this? 'Where does the engine go?' |
1050 Posts Member #: 764 Post Whore Staffordshire |
17th Apr, 2009 at 09:48:23am
what version of the software are you using? |
17th Apr, 2009 at 10:07:06am
Can't help you but which set of roller were you on? and who was operating the road? only reason I ask is that Dave and myself had a similar problem a couple of years back. Isambard Kingdom Brunel said:
17th Apr, 2009 at 10:16:00am
The software is version 3.0 I think,and it was Dave,who IS Mech Motorsport running the RR.He did say he'd seen this before. 'Where does the engine go?' |
17th Apr, 2009 at 06:31:48pm
my suggestion would be to check and re check your wiring and have your mj bench tested then go from there.
Edited by philc on 17th Apr, 2009. |
18th Apr, 2009 at 08:16:10am
wiring is my first priority.Not sure what is meant by flashing(!) 'Where does the engine go?' |
18th Apr, 2009 at 08:21:40am
once you have got your map it needs to be red to the mj (flashing) which is on the tool bar of your map page Edited by philc on 18th Apr, 2009. |
271 Posts Member #: 1844 Senior Member BURNTWOOD, staffordshire |
19th Apr, 2009 at 06:48:09am
Hello
19th Apr, 2009 at 08:23:05am
why did you not go back and complain, or tell him what the issue was, as you say he should have picked it up. He would not have been able to set the timing and do any mapping because of this. sounds like easy money to me, he will continue to do this until someone complains. My advice to anyone going to a RR is to ask if they can setup MJ's, they should be able to as it is the same as anyother type of re-mapping. If they come across as not being confident uming and are-ing don't let them do it and go someone else.
On 19th Apr, 2009 alandavies215 said:
Hello Went there myself and paid best part of £300.00 pounds only to be told not to drive it as running realy lean, he said after he had not done many of these set ups and phoned his mate a couple of times for advice, he had changed all the pipework around. Said the fuel pressure was 10 psi at tick over and dropped when on boost which leaned out. Anyway got it home brought a fuel pressure gauge a was ticking over at 3 psi, I had 2 great lads come and have a look at it after I had put the pipework back to how it was and we found a earth wire no connected to the meggajolt (only runner on the edos) how did he miss this, all in all he suppsed it be good but not up to speed with turbo minis Hope u did not loose out like me LOL A |
19th Apr, 2009 at 09:46:32am
Hello philc
20th Apr, 2009 at 10:11:01am
I went to Dave RR on the advice of RogerM, late of this site.He certainly understands SU setups and engine mapping,including turbos.He is reluctant to spend his time and your money on troubleshooting wiring/plumbing faults.He is not keen on megajolt (as opposed to Omex or Emerald) because of past reliability issues.
20th Apr, 2009 at 02:06:57pm
Steve, did not realise you are only in bromsgrove, i am not saying i could resolve your problem, but i am happy to pop round and have a look, sometimes two heads are better than one |
20th Apr, 2009 at 02:13:30pm
Hi Philc,
