| Home > Technical Chat > RR Today at Emerald findings | |||||||
869 Posts Member #: 2443 Post Whore Cheshire |
17th Apr, 2009 at 07:18:48pm
Alright Chaps,
Edited by Andy500 on 17th Apr, 2009. |
17th Apr, 2009 at 07:28:49pm
I take it you're running the M45 ? If so anything over 10psi seems to be a waste of time. 8 psi seems to be what most folks run on these. |
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
17th Apr, 2009 at 07:29:42pm
instead of intercooling (if space is an issue) or dropping the boost, have you though of water injection to cool the charge? Might be worth a look... |
559 Posts Member #: 2775 Post Whore Aberdeen |
17th Apr, 2009 at 07:35:16pm
What pullies etc are you running. I have an m45 setup and I am only seeing 8psi on my guage? I was considering water injection for the future but need to find out how much water you need and how long it lasts etc. I dont want to be putting in water every five mins. Any pics of your setup |
17th Apr, 2009 at 07:35:41pm
Yep running the m45 as supplied by Vmax Scart. It uses the standard mpi crank pully and bmw charger pulley. So i guess all the other people running the same mpi kits will be suffering with high boost as well. Just seems odd that stuart wouldnt have looked in to this.
17th Apr, 2009 at 07:53:39pm
maybe you got given the wrong pully? is it a carb or inj? have you thought about air ducts to the charger to see if that helps cool it down? Drives
17th Apr, 2009 at 07:54:49pm
What is the diameter of your standard pulley? |
17th Apr, 2009 at 09:40:08pm
have you thought aboput adding a very small amount of N2O to cool in inlet charge, |
17th Apr, 2009 at 10:24:59pm
carl has a good point, the n2o will cool the charge signficantly, maybe just add a few hp of n2o aboube about 7 psi (oil pressre swtch pressure) On 28th Aug, 2011 Kean said:
17th Apr, 2009 at 10:59:21pm
how much room is trhere to lift the supercharger, before it hits the bonnet, |
17th Apr, 2009 at 11:11:50pm
not much unless you kick the back of the bonet up.
17th Apr, 2009 at 11:23:05pm
what about that cryo2 stuff? co2 cooling on the inlet charge they do small spray kits could do one over the supercharger like you would on an intercooler?
Edited by Paul R on 17th Apr, 2009. Drives
17th Apr, 2009 at 11:25:03pm
could do, bit how much surace area doue the sc habe?
17th Apr, 2009 at 11:55:35pm
I had thouht about those cryogenic kits and they my be the way forward.
18th Apr, 2009 at 12:31:37am
haha i have got it :) you know thoes gay chav "nitrous plurge kits" which get wired into your windscreen washer fluid tank, they produce a nice fine spray from there jets, cheap as they are chavy and easy to use and maintain as your just wiering in a new washer jet bottle and pump, never thought about that untill just now how cool? Drives
18th Apr, 2009 at 01:03:23am
The biggest problem with any sort of N2O or water injection is that it is not a continuous system, it eventualy runs out.
Edited by Sprocket on 18th Apr, 2009. On 26th Oct, 2004 TurboDave16v said:
1425 Posts Member #: 690 Post Whore Norfolk |
18th Apr, 2009 at 08:53:12am
Another solution would be to build a new inlet manifold with a chargecooler in it, utilise the space to the rear of the bulkhead area. Lots of cars use this solution, take a look at the s/c kit for the new MX5 for a good example. The company to talk to about parts is Magnusun in the US as they engineer most of these kits for the oems/aftermarket.
If Carling made Mini engines
18th Apr, 2009 at 10:08:30am
On 18th Apr, 2009 Sprocket said:
The biggest problem with any sort of N2O or water injection is that it is not a continuous system, it eventualy runs out. I have thought for a long time that the solution to this problem is to fabricate some sort of spacer block that acts as a discharge of the compressor, so you can take off the discharge air from underneath, feed it through an intercooler and then back to the other side of the block and into the manifold. Two seperate channels in the block obviously. There is loads of room on that compressor outlet, its fookin huge and only a tiny part of it is used on the mini. Then its a matter of injecing the fuel after the intercooler but before the manifold. This all depends on how much room there is above the charger. But I would imagine you could do this with maybe a 1" block with the apropriate width hole for air flow. I mean, the supercharger inlet manifold is not exactly the most efficient of designs is it. As long as the airflow is not restricted it should work. Sprox, ive been thinking about exactly the same things as well. But obviously it will take quite a bit of design and trial which would no doubt mean a huge cost, but it would be the best long term solution. As it stands most of the outlet air from the charger is blasted against a plate before it can get down the mouth of the inlet. John, how good can these charge coolers be? would it cause problems with the charger running in a wet set up?, would the cool surface of the exchanger pull the fuel out of the airstream? |
18th Apr, 2009 at 10:12:04am
On 18th Apr, 2009 Paul R said:
haha i have got it :) you know thoes gay chav "nitrous plurge kits" which get wired into your windscreen washer fluid tank, they produce a nice fine spray from there jets, cheap as they are chavy and easy to use and maintain as your just wiering in a new washer jet bottle and pump, never thought about that untill just now how cool? What are these? would i inject it it in to the airstream or do you mean as a mist to spray over the charger? |
19th Apr, 2009 at 05:51:52pm
to spray over the charger as a thought cools it down then but not sure if it would work that well was just an idea :) Drives
19th Apr, 2009 at 07:26:44pm
If there cheap and easy then it may well be worth a shot, where do you get them from? |
19th Apr, 2009 at 10:14:20pm
Right ive spent the evening looking at solutions to my problem and was quite in to the idea of water injection, that is untill i did a search for it on here.
19th Apr, 2009 at 10:21:55pm
Cant you change the bottom pulley? I can measure mine if you like and see how it compares to yours? |
19th Apr, 2009 at 10:24:58pm
Hi Lockfast, tha would be great if you dont mind. Are you running your system on an injection engine or carb? Also are you using a 5PK serpentine belt? Whre did you get your pulley from?
19th Apr, 2009 at 10:28:53pm
Give me 10 min will go and measure |
