Home > Help Needed / General Tech Chat > Compressor Map Help
PaulH
Member #: 2340
Dublin Ireland
Ok have been at this all week and now my brain hurts.
The figures I have used to work out my presure ratio and Lb/min:
HP : 200
Displacement: 1380cc
Max rpm : 7500
VE : 85% (maby a bit optimistic for a 5 port)
AIT: 100 deg F
BSFC: .50
AFR 12:1 (Hif 44)
What I came out with is -
Wa : 22
MAP corrected : 15 psi
MAP Absolute: 29.36
P1c: 13psi
P2c: 17psi
IIc: 1.30
The two things Im stuck on:
is Wa my corrected Air flow
and does a Presure ratio of 1.30 sound right for this spec ?
Edited by PaulH on 17th Apr, 2009.
On 17th Feb, 2009 Rob H said:
personally, i just use this,
http://www.motorgeek.com/index.php?page=6
try to find a known poer output to "calibrate" and go from there.
also your VE may be slightly optimistic, but i think you can lower the bsfc to the .45 area, prhaps as low as ,42 on a low boost high cr engiune
PaulH
Member #: 2340
Dublin Ireland
What an Awesome sight thanks a bunch dood
no probs :)
Kean
Member #: 341
aka T2clubby
South Staffs
Wa is your airflow, and I think the pressure ratio will be more like 2.3...
PaulH
Member #: 2340
Dublin Ireland
Ya T2 I Think your right but I'm nearly sure it should be Mid 2.3, Ill have to go back over my calcs tommrrow.
I think the air flow is 22 Lb/min
