Home > Beginners Tech > supercharger to turbo
greymini78
Member #: 2408
surrey / ewell area.
As the title really,taking my supercharger off at the end of this season and will converting to turbo carb. Im currently running 8psi on a bini sc would this mean i could theoretically run 8psi via a turbo and still be as reliable or do i need to consider higher charge temps etc i will be running a small IC so maybe run 10psi?Just dont want to start taking my head off if i dont have to.
Engine spec...
1293cc
dished cast pistons
centre main strap
orange diaphram/fast road clutch
8.5.1 comp
P.S anyone used those KAD crank pulleys
A good Turbo will be far more efficient than the M45, so your charge temps will be lower, plus you have the option to intercool.
Good times !
greymini78
Member #: 2408
That is exactly what i hoped to here Phil , shall i pm nearer the time for those bits ?
Yes no problem. I've PM'd you anyway.
