Home > Help Needed / General Tech Chat > Minispeed turbo cam
Mr Joshua
Member #: 1954
Luton Bedfordshire
I find myself with a small problem. Having purchased the above item well over a year ago, and having fitted it to an engine that I had sat as a spare, I have no idea what the timing for this cam is.
Having done a quick search there is no info on here with regard to these cams.
The only mention I have found was that it was thought to be a copy of the Kent 500 cam. Now I know this is a stretch but I have set the timing to 110 degrees which is the same as the K500 and seems to be the standard timing for after market cams.
Good assumption or living dangerously?
Own the day
you have timed the inlet at 110deg BTDC,
just check that the exhaust is timed at 110 deg ATDC,
if it isn't se how far the exhaust is out half the diference and retime the cam acordingly *wink*
Mr Joshua
Member #: 1954
Luton Bedfordshire
Sorry, but maybe im just being a little thick or my engines are mirical engines but dont you mean the inlet valve is timmed to reach full lift 110 degrees ATDC on the induction stroke? And the Exhaust valve reaches full lift 110 degrees ABDC on the exhaust stroke?
Own the day
inlet 110 atdc ,ex 110 btdc .
Why not give Minispeed a call and ask them what the preferred timing is??
assumption is the mother of all f**k ups, heed toms advice
Mr Joshua
Member #: 1954
Luton Bedfordshire
I was hoping for adifinative answer otherwise its feet up, watch startrek re-runs and make the call Monday.
Thanks
Own the day
Mr Joshua
Member #: 1954
Luton Bedfordshire
The exhaust is timed at 110 degrees ABDC. Followed the Calver guide and this is what I came up with.
I'm gong to leave everything as is until I can talk too mini speed No rush I’m not driving her till she is resprayed and that’s not going to happen for at least another eight weeks :)
Cheers.
Own the day
[/quote]The exhaust is timed at 110 degrees ABDC. Followed the Calver guide and this is what I came up with.
[/quote]
I'd prefer it being timed 123 at ABC*happy*
Mr Joshua
Member #: 1954
Luton Bedfordshire
Great! Now they want the number of the end of the cam.
Own the day
Well, it is about 35-40 degrees away from where it should be !!!!!
