Home > Help Needed / General Tech Chat > selecting a compression ratio - 10 psi supercharged engine
nobbycameron
Member #: 5871
my understanding is that you want the compression ratio as possible without pre detonition. Is there a way of calculating this for a forced induction a series.
i am aiming for 10 psi from my eaton m45, what is the maximum comp ratio i can run without pre detonation????
cheers
lot of factors effect det
realistically on an iron head 'a' series:
cr
timing
charge temp
with more info, others might be able to help you find an answer, but if you consider the stock metro ran 7psi, and alot of guys on here run much more on std cr, (but with ic's and mj).
im not sure how using a sc will affect det, but someone might point you in the right direction
a search will probably reveal a hell of a lot of info
Firstly, no such thing as pre detonation. There is pre-ignition caused by the fuel air mix igniting before the spark. There is also detonation which, put simply, is igntion in the combustion chamber caused by the pressure wave generated by the spark.
However, both have similar causes and effects.
Pre-ignition and detonation are not caused by boost alone but more by a high inlet charge temperature. So you need to take into account the supercharger efficiency and if you have an intercooler.
There is no simple way to calculate the maximum compression ratio. Most people use trial and error and others experiences.
At 10 psi, a wel intercooled turbo engine could run as high as 9.5:1 without problems.
However, with a M45 supercharged engine without an intercooler, I would not start any higher than 8.5:1, simply because of the higher inlet charge temperature.
Just my opinion that may not be correct.....
I tun 9-10 on a suck through at 8.7:1
how does the SC12 compare to the m45 efficiency wise though?
what sort of charge temps do you see?
hario
Member #: 2885
Surely a modern supercharger like that is machined tight enough to be used blow through allowing intercooling, unless its one of those manifold mounted type?
yes same thoughts as pauls 8.5:1 is a safe margin on 95ron fuel
