| Home > Help Needed / General Tech Chat > Megajolt loosing spark! | |||||||
19th Apr, 2009 at 07:32:26pm
I have just put my engine back together and had it driving fine last week. It was running rich but i seem to have sorted this by redoing my choke seals and resetting the fuel pressure.
19th Apr, 2009 at 07:41:11pm
if the rpm in the megajolt sotware is going to 0 that points to the VR sensor.
19th Apr, 2009 at 07:41:19pm
have you checked all of your power connections and earth's |
19th Apr, 2009 at 07:42:44pm
You havent accidentally changed the rev limit setting in the software have you? |
19th Apr, 2009 at 07:58:51pm
I have checked the powers and earths and they seem to be ok and holding when i have the missfire. If you look at the table where you edit the map it drops to the lowest value. However i didnt look at the rev counter on the megajolt software.
Edited by Star Mag on 19th Apr, 2009. |
19th Apr, 2009 at 08:59:59pm
I had the same issue it dropping to 0. the consensus was:
Edited by gr4h4m on 19th Apr, 2009. I run a supercharger and I don't care the TB is on the wrong side.
19th Apr, 2009 at 09:52:12pm
The sensor position hasn't moved and it's been working for about two years. Although I did check it. Where did you get your sheilded cable from? |
20th Apr, 2009 at 11:43:28pm
sent you a PM but it was from my local RR. I run a supercharger and I don't care the TB is on the wrong side.
12th May, 2009 at 10:33:28pm
I have sorted my Megajolt problem after a lot of head scratching!
