| Home > Help Needed / General Tech Chat > Cast Omegas Pistons for Turbo use | |||||||
![]() 465 Posts Member #: 1972 Senior Member Worcester |
19th Apr, 2009 at 09:01:35pm
Hi, im finally getting close to the stage where i will be building my motor, would appreciate some advise from those with experience:
19th Apr, 2009 at 09:06:03pm
Low comp height pistons woule mean that the crown is miles from the top of the block at TDC. NOT good for combustion. Do it properly, get some correct pistons. On 13th Jul, 2012 Ben H said:
19th Apr, 2009 at 10:10:33pm
What are these low compression high pistons good for?
19th Apr, 2009 at 10:26:50pm
the low height ones should be ok in my experience, my mate runs a set of low height forged flat top omega's at 8:1 and is around 200 banana's. On 20th Oct, 2015 Tom Fenton said:
19th Apr, 2009 at 10:31:36pm
On 19th Apr, 2009 Nic said:
What are these low compression high pistons good for? If i put them in a short stroke n/a engine and skimmed the block to suit, what would be the downside? They are for 83.5mm crankshafts etc.. On 13th Jul, 2012 Ben H said:
19th Apr, 2009 at 10:31:47pm
wouldnt a low comp hieght piston in a short stroke motor just put the pistons even further down the block? so even more skimming? |
20th Apr, 2009 at 07:02:57am
for every 0.010" down the bore from TDC is .... 1cc on a 1380 ..... so add a further 22.4 ccs into you calcs
20th Apr, 2009 at 08:38:47am
Yes they do sit very low in the bores, 1.6mm down, which is why i can get the compression ratio so low with 11cc pistons and 28cc head
20th Apr, 2009 at 08:56:03am
yes! the cast omegas are well proven with over 20 psi of boost.
20th Apr, 2009 at 09:43:59am
Cheers Steve, thats what i wanted to hear! Should finally get round to using that cracking head you did me soon! |
20th Apr, 2009 at 09:57:32am
What problems, other than poor combustion, are associated with running pistons so far down the bore?
In the 13's at last!.. Just |
20th Apr, 2009 at 12:36:09pm
On 20th Apr, 2009 theoneeyedlizard said:
What problems, other than poor combustion, are associated with running pistons so far down the bore? Detonation is your worst enemy. The thing is, if you run the pistons flush, you geta a higher static CR, but the amount of boost before detonation might be the same. So, a proper combustion chambre is a win win situation. The number on the compression ratio is not all that matters. On 13th Jul, 2012 Ben H said:
20th Apr, 2009 at 12:58:06pm
Cheers V In the 13's at last!.. Just |
20th Apr, 2009 at 01:57:15pm
Vegard, what are your thoughts on running the pistons above the deck head, assuming you can get the CR required? On 15th May, 2009 TurboDave said:
20th Apr, 2009 at 02:08:00pm
A little bit above is good for squish, although too much and you know what happens under high RPM. It also depends on the squish band on the pistons. Too wide and one may actually get pre ignition from the locally very high pressure toward the outside of the squish band.
Edited by miniminor63 on 20th Apr, 2009. |
20th Apr, 2009 at 02:08:56pm
I know for a fact that this is what top racing engines do, but rod-stretch will be an issue with a high revving engine, and also with a big bore as the gasket is smaller in diameter. Anything to get maximum squish.
21st Apr, 2009 at 02:30:30pm
On 20th Apr, 2009 Vegard said:
combustion chambre Bloody hell, you speak french too |
21st Apr, 2009 at 02:54:12pm
I know for a fact that this is what top racing engines do, but rod-stretch will be an issue with a high revving engine, and also with a big bore as the gasket is smaller in diameter. Anything to get maximum squish. However, if you're running 50psi this all alters judging by various books concerning GroupB rally cars and F1 turbos. My limit is 33psi, will not be hitting 50 psi with this turbo, but the one I have on the shelf....... On 15th May, 2009 TurboDave said:
21st Apr, 2009 at 03:18:40pm
33psi!!!! How much power? If something is worth doing, it's worth doing half of. |
21st Apr, 2009 at 03:36:12pm
On 21st Apr, 2009 minimadmotorman said:
33psi!!!! How much power? Go and buy this months minimag and you'll see. Or search for the thread on the Twink RR day on here. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
21st Apr, 2009 at 03:59:07pm
that was on only 24.47 psi though... |
21st Apr, 2009 at 04:02:57pm
Still 25psi is impressive. If something is worth doing, it's worth doing half of. |
23rd Apr, 2009 at 07:33:09am
the cast omegas will be good , t3tone is running the same pistons for years in his 1380 turbo always looking for them bigger bunches of bannanas |
23rd Apr, 2009 at 08:34:25am
Cheers for advise turbo hogster |
23rd Apr, 2009 at 12:14:01pm
On 20th Apr, 2009 miniminor63 said:
A little bit above is good for squish, although too much and you know what happens under high RPM. It also depends on the squish band on the pistons. Too wide and one may actually get pre ignition from the locally very high pressure toward the outside of the squish band. You know why your miglia engine builder have his name right? You won't get pre-ignition from Squish... Quite the opposite in fact. Alex AlexF |
