Page: |
Home > Help Needed / General Tech Chat > smoking on over run | |||||||
2623 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
24th Apr, 2009 at 11:36:18pm
There is a fair bit there but what I really cant get my head round is the compressor housing is spotless!
24th Apr, 2009 at 11:48:45pm
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
25th Apr, 2009 at 05:18:25am
ould easily still be the turbine side oil seals. had it happen myself on a few occations before i realised my turbo oil driain (and breather) was less than satisfactory. each time it smoked on over run and occationally at idle but the compressor outet was always clear. replacing the turbo always cured it. turbo 16v k-series 11.9@118.9 :)
25th Apr, 2009 at 07:31:27am
either exhaust side of turbo or the dreaded piston ring lands have failed like mine did, what pistons are you running
25th Apr, 2009 at 10:29:53pm
On 25th Apr, 2009 turbo hogster said:
either exhaust side of turbo or the dreaded piston ring lands have failed like mine did, what pistons are you running |
25th Apr, 2009 at 10:34:15pm
if the ring lands are gone shouldnt it show up on a compression/leakdown test? On 28th Aug, 2011 Kean said:
26th Apr, 2009 at 12:22:13am
Ive not done a compression test on the engine yet, will do it tomorrow, just out of curiousity.
1497 Posts Member #: 100 Parisien Turbo Expert Paris\' suburb |
26th Apr, 2009 at 07:35:58am
when I think about this, I'm not sure why you should be nervous about this, in the back of my head I'm not sure that any turbo mini I had, hadn't made this less or more when the breather are disconnected from vaccum .
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
26th Apr, 2009 at 11:08:11pm
That does not compute the compressor housing is clean but the coupling pipe is covered in oil!
Own the day
1346 Posts Member #: 2340 Post Whore Dublin Ireland |
26th Apr, 2009 at 11:40:10pm
My money is on turbo seals Exhaust side tbh On 17th Feb, 2009 Rob H said:
1st May, 2009 at 06:43:24pm
Well, have a new turbo ready to fit. But parts I ordered from mini sparwes havent arrived so not going to get it running this weekend, not happy!
102 Posts Member #: 5814 Advanced Member Kidderminster |
5th May, 2009 at 10:18:08pm
Mine does the same shane, and im interested to know if yours stops smoking when you replace the turbo seals? Cheers, hope all goes well More Boost, More FUN! |
Page: |
