| Home > General Chat > monkeys! | |||||||
![]() 1128 Posts Member #: 142 Post Whore Winchester |
26th Oct, 2004 at 11:45:11am
i was out working on my girlfriend's brother's car with him because he got the brake cylinder's replaced by a garage, we were checking them out because the brakes were rubbing like mad, i tried to undo the wheel nuts with a brace and i could't so i got my torque wrench out to check them, the book said 66lb/ft on the wheel nuts (renault clio) |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
26th Oct, 2004 at 11:56:49am
shouldnt really undo things with a torque wrench, but like you say, you shouldnt need to either. Trouble with gargaes is they use a windy gun for everything!!
And on the 7th day........... God created turbochargers! |
26th Oct, 2004 at 11:58:38am
it was the longest thing i had to hand, they were so tight!
19 Posts Member #: 378 Member |
26th Oct, 2004 at 12:58:06pm
i just changed the rear pads on my bosses van (nissan primestar) and the wheelbrace supplied was only 12" long and a realy strange shape ??? we happened to have a 6' steel tube to extened it with and that only just did it !!!! (wouldnt like to have to try and do a puncture on the motorway)
will probably explode !! |
26th Oct, 2004 at 01:29:49pm
I never let the monkeys who do tyres tighten my wheel nuts up. Let them take them off, then I put them back and torque up myself using a torque wrench. Also they do a good line in busting your locking wheel nuts using a windy gun on them as well......
26th Oct, 2004 at 01:59:27pm
Doesn't it take 1/2 the force to undo something than it does to tighten it up? (roughly)
26th Oct, 2004 at 02:03:37pm
thats really tight ..... does geof capes work at that garage ??? will probably explode !! |
26th Oct, 2004 at 02:34:11pm
the noise when the nut actually undid was terrible, the nut was so tight to the wheel that ist had alsmost worn a groove in to it.
26th Oct, 2004 at 02:37:59pm
not geoff capes......his best mate......mr chicago pneumatic windy gun......
Edited by Tom Fenton on 26th Oct, 2004.
26th Oct, 2004 at 02:45:15pm
the threads were not rusty, i think i might check the front wheels for him soon, they had them off too, when i did them back up to 66lb/ft i tried to undo them again with the wheel brace and it was much easier, when we started even with nearly all my weight on it (13 stone, need to lay off the pies a bit!) there was no way the nud was coming undone.
26th Oct, 2004 at 02:47:22pm
when you have them off get some copper grease on then......
26th Oct, 2004 at 02:58:38pm
i will , i have some in my toolbox somewhere i think, i always used to think the only use for it was to stop brakes squeling i only recently found out it stops things seizing up, do you just a little bit on each stud?
26th Oct, 2004 at 03:09:46pm
yeh, just a little smear will stop them seizing, really does only need to be alittle bit, goes a long way! And on the 7th day........... God created turbochargers! |
26th Oct, 2004 at 03:24:02pm
Copper grease is great stuff. Use it on pads like you say. But also any threaded fixings which are prone to seize. I use it on wheel bolts/nuts, exhaust manifold studs, thermostat housing studs, and last but not least, rear subby mount bolts....
26th Oct, 2004 at 03:29:07pm
i can understand the thermostat nuts, i skinned my knuckles quite badly when mine snapped off and i punched the bonnet slam panel.
26th Oct, 2004 at 09:16:35pm
copper grease on thermostat nuts is agodsend ! turbo 16v k-series 11.9@118.9 :)
260 Posts Member #: 239 Senior Member Somerset |
26th Oct, 2004 at 10:12:12pm
hell copper grease everything!!
Cheers, Stevo |
