Home > General Chat > wheel width, offset, BackSpacing ...... & classic MINI
fritz
Member #: 2331
Nuernberg (Nuremberg, Franconia in Bavaria), Germany
maybe of help .....
Wheel Technical Information
www.rsracing.com/tech-wheel.html
Some time ago, I tried to compare wheels dimensions for
the classic 10" wheeled Mini with factory fitted 7.5" disc brakes.
For normal road use with 165/70/10 tyres ..... a n d allowing to fit the wheel/tyre combination on an original factory look Mini Mk3 without flares!
The track should be remain as "narrow" as possible ..... I think a few rims with 4,5" width - or even up to 5,25" - can do the job.
If only their rear spacing (back spacing) is 100 mm or more.
(see the following EXCEL sheet).
Kind regards
Fritz
SORRY ..... should be a reply to the thread WHEELS..
Edited by fritz on 22nd Apr, 2009.
