Home > Help Needed / General Tech Chat > Loud blowing noise
longy
Member #: 2727
Bicester
Hi guys, driving to work this morning my n/a 1275 engine started making a noise like something was blowing (rather then tapping), i can only hear it under load. i thought it was the exhaust manifold to head gasket so ive just replaced it, but doesnt seem to make any difference. the exhaust system seems to be ok, but havent yet had a look under the car for any cracks or holes, there doesnt seem to be any drop in performance. dont suppose anyones got any ideas?
(Hopefully nothing terminal)
1972 998 TURBO SLEEPER
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I cracked my LCB when I didn't have the bracket to the gearbox. Couldn't find the noise, it wasn't the joins or the manifold gasket but then I found the crack.
On 7th Nov, 2008 Nic said:
naeJ
m
longy
Member #: 2727
Bicester
thanks Jay i think ill take the lcb off tonight and examine it.
Jay#2
Member #: 648
If it is an exhaust blow, you might be able to hear if it is down near the Y piece or at the gasket. If it is hard to distinguish then it could be a crack half way down like mine.
naeJ
m
Mr Joshua
Member #: 1954
Luton Bedfordshire
Get under the car and spay some WD40 on it the blow will become very obvious.
Own the day
Ric
Member #: 36
Basingstoke
good excuse to go turbo longy *wink*
longy
Member #: 2727
Bicester
I know Ric, im slowly gathering parts. well ive solved the issue with the noise. head gasket was blowing between 2 and 3 cylinders. changed it lastnight going to run it tonight and see how it goes. the head was fine, i checked it with a straight edge and feeler gauges. the engine didnt get hot enough to do any damage
