Home > Help Needed / General Tech Chat > Crunching on downchange in 2nd...baulk rings?(post after video)
mayoturbo
Member #: 1395
chepstow
I have a rattling noise when then clutch pedal is NOT depressed which goes away when it is depresed.
The car will crunch into reverse but if you keep the clutch depressed and take it out of gear then put back in it goes in fine.
The car also crunches into 2nd and all the other gears dont go in that sweet but they dont crunch, feels abit stiff to push in but once in go in fine if you leave the clutch depressed and re-select.
I have the minispares straight cut gear set, minispares drop gears with timken idler.
Could it be the tolerances on the primary gear wrong?
Edited by mayoturbo on 9th May, 2009.
Release bearing?
mayoturbo
Member #: 1395
chepstow
release bearing is new
rattling will be drops rattle (normal) gears are probably stiff syncros
Is the box newly rebuilt?
mayoturbo
Member #: 1395
chepstow
yes the gearset is new and replaced the double roller and another bearing. I also lost a detent ball so replaced with a different ball bearing the same size.
Is anyone going to the riviera run with the same drops so I can hear if its the same noise?
thanks
Ill have a gander for you mate. Come and find the tangerine and say hello.
So you deffo going in the tangerine machine then mike? Have you tried that boost gauge yet?
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Mayo just make sure the clutch throw-out stop is set right. Sounds like the clutch is not releasing fully.
"Try to take over the world!"
Yeah, i must have bewn creating mega boost, its now set at7
Yeah, i must have bewn creating mega boost, its now set at7 checked it with the mj, just waiting for a new alternator from matty to arrive!
Have you ordered a new gauge then or do you want to borrow mine for a while?
Ive ordered 1 mate, fuckin iphone making me double post!
The rattle on the drops is probably fine, they all do that
Double check your clutch adjustments, i find reverse is always the first to crunch if something isnt set quite right
Mr Joshua
Member #: 1954
Luton Bedfordshire
I had my drops set at .006" end float and was told that was far too much so now its 0.0025. Any idea what your idler gear end float is? Is this ratttle new or present since build?
Own the day
Rattle is fine, i bet its like a clacking nouise.
mayoturbo
Member #: 1395
chepstow
Thanks for the replies. Im sure I wont miss the tangerine!
The biting point also feels abit low, time to convert to hydraulic I think. I will check the throw out stop.
The rattle wasn't there before, everything was standard metro then.
How do you set the idler gear end float with the timken idler?
mayoturbo
Member #: 1395
chepstow
Cant really hear much(great quality *tongue*) but at the end of the video is engaging the clutch and disengaging a few times
mayoturbo
Member #: 1395
chepstow
Car does not crunch into reverse and gears feel alot better now but it still crunches into 2nd, it only does it on down changes though. Does this sound like baulk rings?
PaulH
Member #: 2340
Dublin Ireland
YES
On 17th Feb, 2009 Rob H said:
Yes a shafted baulk ring will be the cause of this mate.
