Home > Help Needed / General Tech Chat > Alternator relocation
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Just getting the IC mocked up and as I felt all allong I can't get it low enough to get behind the grill. If I could drop the alt down a bit I think that would be the solution. I thought of one of those wee Nippon Densos but they still mount at the same height and give more room at the front if you know what I mean.
Any ideas how I can do this? I think I could make a new bracket that goes on the block with the tab for the alt at the bottom rather than the top then make something that would bolt to the front of the water pump with a tab lower down. Just about 2" would do it!
Thanks,
Jay#2
On 7th Nov, 2008 Nic said:
naeJ
m
Sounds like a plan. Use the existing mounting points on the block and some home made brackets to lower it.
turbominij
Member #: 2104
Essex - UK
Lowered Alternator !!! dont tell the chavs they will want them too.
sounds a good plan if you can pull it off let us know (i have a similar space issue)
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
