| Home > Help Needed / General Tech Chat > running a new engine in? | |||||||
72 Posts Member #: 5062 Advanced Member Herts |
25th Apr, 2009 at 09:45:09pm
I've been looking into the different ways of running my 1293 turbo engine in (when its finished), i'm very tempted to go down the boot it from the start route and have been thinking about taking the engine to somewhere like in Bills 1380 dvd for them to do it? it'll be running mejajolt if that makes a difference?
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
25th Apr, 2009 at 09:54:53pm
check out the how to section - benross has some sound advice in there which I just followed for my daily drive and seems to have worked well On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
25th Apr, 2009 at 10:04:46pm
you need to have some confidence that the engine is not running masivly lean or advanced before you go down that route.
26th Apr, 2009 at 10:56:31am
follow this to the letter, http://www.mototuneusa.com/break_in_secrets.htm
26th Apr, 2009 at 11:41:00am
my plan personally is to bed the cam in like Mini13 says and then go to the rollers to have it set-up for low boost.
26th Apr, 2009 at 11:43:45am
i pretty much do as mini13 said. start it up and run at high idle to bed the cam in, check the engine over, take it for a drive, going on and off boost, starting easy and building up as you clock up the miles. you will feel it free up and then its good to go.
26th Apr, 2009 at 12:36:08pm
I think ill do sort of as James says.
26th Apr, 2009 at 01:47:22pm
Yep, fixed RPM driving e.g. motorway or dual carriageway will just polish the bores, you want to be up and down the revs using up to about 2/3rds throttle.
26th Apr, 2009 at 07:02:22pm
Mine was 100miles hard driving with not so much high revs, then it was on the dyno for 2 hours the last hour with 8000rpm limit, lol, and it was run in On 26th Oct, 2004 TurboDave16v said:
26th Apr, 2009 at 07:11:30pm
My newly built 998 went straight into service testing the Siamese Code after bedding in the cam.
26th Apr, 2009 at 09:32:58pm
In 1962, when I was involved with race/rally minis,the fastest ones were always the ones that had been thrashed the most. This is not necessarily a good indicator of how long they lasted. |
27th Apr, 2009 at 06:59:04am
most race engine builders use different tollerances to road engines as the race engines are expected to be thrashed from new |
27th Apr, 2009 at 09:14:03am
The main thing is just don't labour the engine!
27th Apr, 2009 at 01:23:44pm
shit oil helps bed engine in Crystal Sound Audio said:
27th Apr, 2009 at 04:23:57pm
with my engine, I bed the cam bearings in, for about 10 mins, then mapped it on the rollers, this took a few hours. By the time the mapping was done we where up to 20psi and 7500rpm. On 15th May, 2009 TurboDave said:
28th Apr, 2009 at 07:25:13pm
Sound like my kind of guy -give it a bit of kindness and then thrash it so it knows who is boss !! |
28th Apr, 2009 at 08:24:08pm
i guess thats a good point with an efi engine,
On 27th Apr, 2009 Jimster said:
with my engine, I bed the cam bearings in, for about 10 mins, then mapped it on the rollers, this took a few hours. By the time the mapping was done we where up to 20psi and 7500rpm. On 28th Aug, 2011 Kean said:
29th Apr, 2009 at 08:03:48am
Rollers are best as Jimbo says On 5th Sep, 2011 Vegard said:
