| Home > Wanted > 4 Pot Alloy 7.9" Vented Calipers | |||||||
1050 Posts Member #: 764 Post Whore Staffordshire |
28th Apr, 2009 at 09:06:20am
A bit of a long shot i know, but I am after a pair (or just a minisport passenger side) Alloy 4 pot callipers for 7.9" vented discs.
28th Apr, 2009 at 01:27:42pm
whats the story? nipple housing cracked?
28th Apr, 2009 at 06:26:33pm
had em done with a M10, but it not sealing due to a kinda chip in the seat, nowt more we can do with them. They do seal with a small rubber o-ring but it makes bleeding em a complete pita.
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
28th Apr, 2009 at 06:32:25pm
you can get the minispares set cheaper than that!! On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
28th Apr, 2009 at 06:32:58pm
bummer
28th Apr, 2009 at 07:06:00pm
You can get 'bleeder repair' kits just for this. They screw into a 1/8 NPT or 1/4NPT theaded hole that you machine where your damaged bleeder was, and then thread in this magic unit...
28th Apr, 2009 at 07:35:29pm
is this what you mean?
28th Apr, 2009 at 07:43:32pm
That's the bugger - and damnd that's cheap!
28th Apr, 2009 at 07:49:32pm
fan fucking tastic :) :) thanks Dave... i shall order one now and give it a go... cheers! Edited by Anton on 28th Apr, 2009. |
28th Apr, 2009 at 08:55:33pm
wicked, good work TD "Turbo's make torque, and torque makes fun"
28th Apr, 2009 at 09:57:27pm
At that price, get two... Handy to have on the shelf just in case you ever need such a repair... On 17th Nov, 2014 Tom Fenton said:
28th Apr, 2009 at 10:15:11pm
too later ordered it now.. also goto one of these as i like the idea of it being mag mounted
29th Apr, 2009 at 08:07:44am
I like this presumably suitable for joining pipes?
On 5th Sep, 2011 Vegard said:
29th Apr, 2009 at 08:19:17am
I just bought the same bit in Norway ( 1/4NPT thingy for £10... bugger.. On 13th Jul, 2012 Ben H said:
29th Apr, 2009 at 09:08:55am
On 29th Apr, 2009 Scruffy said:
I like this presumably suitable for joining pipes? http://www.agriemach.com/product_info.php?...e7tgv4a144vc5u2 yeah i had to get someone with one of those to mod my playmini pipe so it fitted to my maniflow manifold. they are alot cheaper than i thought |
29th Apr, 2009 at 09:55:24am
Finding a tap however has proved difficult... On 13th Jul, 2012 Ben H said:
29th Apr, 2009 at 10:19:22am
I've got one of those pipe expanders at work. they are ok, but they do take some force to expand the pipe!
29th Apr, 2009 at 05:36:15pm
Those expanders are really only good for thin stuff - 1mm stainless for example will break it into tiny pieces. Where they are best - is for 'cleaning up' existing diameters which have been squeezed by exhaust clamps - like the LCB y-piece into the main exhaust for example. On 17th Nov, 2014 Tom Fenton said:
29th Apr, 2009 at 05:56:33pm
I've a set of those expanders, I was hoping they were going to be fantastic but in fact they are wank!!
603 Posts Member #: 1938 Post Whore near Dundee |
1st May, 2009 at 08:15:55pm
http://www.agriemach.com/product_info.php?...products_id=868
1st May, 2009 at 09:03:26pm
well its turned up, and its got a 1/4" - 18 NPT thread on the outside.. there is not enough meat in the calliper to fit it :(
1st May, 2009 at 09:20:50pm
wilwoods have a nipple in a removable insert as std, rally design do 4 replacements for a tenner,
1st May, 2009 at 09:44:00pm
the minisport calipers i have infront of me have the same thing. i cant get it out but it looks to be around 10mm |
1st May, 2009 at 10:48:37pm
hmmm interesting... i may give rally design a call then... if someone already makes an m10 outside thread version i might as well get that instead... although i was a great excuse to purchase a pillar drill :) |
