Home > Help Needed / General Tech Chat > deck volume
fordimus maximus
Member #: 1357
telford,shropshire
Im trying to work out my CR and im stuck with my deck volume?
ive measured from top of block to top of piston and got 0.90mm.
could any tell me how to convert this into deck volume cc please, ive done a search but found loads of formula which wen i punch the numbers in gives me a load rubbish(not doing sumat right)
anyway my bore size is 71.12 if this helps.
cheers
jamie
I think its 4.45cc
Anton
Member #: 764
Staffordshire
pi * (71.92/2) squared *0.090
Edited by Anton on 29th Apr, 2009.
3.93
Anton
Member #: 764
Staffordshire
ang on ignore me thats not right
fordimus maximus
Member #: 1357
telford,shropshire
wen i did it i got 3.57. not sure if this was right tho?
3.57cc
Anton
Member #: 764
Staffordshire
i make it 3.57cc?
fordimus maximus
Member #: 1357
telford,shropshire
nice 1 thanks chaps. could you post up how you came to this so i can double check the method?
t3gav
Member #: 229
Gavin@minispares.com
kent
Just do pi*r^2 xheight ie 3.1415*(71.92/) x 0.9 and then divide by 1000 to go from mm^3 to cubic centimeters
Mr Joshua
Member #: 1954
Luton Bedfordshire
Dont forget the head gasket a BK450 works out to be around 6cc correct me if I am wrong.
Own the day
I thought BK450 was 3.8cc compressed?
Edited by John on 29th Apr, 2009.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Sorry you are correct think I quoted the volume of a decompression plate, oops!
Own the day
t3gav
Member #: 229
kent
We list it as 4cc
So am not a million miles off then :)
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Dont forget to add in the volume of the dish in your pistons........
"Try to take over the world!"
fordimus maximus
Member #: 1357
telford,shropshire
right, now im confused!!
on the CR calc that i have the dish size and head gasket values are in separate fields so this does not need to be added to the deck volume value then, correct?
thanks for the posts guys
Edited by fordimus maximus on 29th Apr, 2009.
Dont forget your ring land volume if you want to do it properly.
t3gav
Member #: 229
kent
They are different things, they are added up sepearately if that makes sense. Bascically your deck volume is 3.57.
if he is using the calculator i think he's using it gives boxes for head gasket, piston dish ect but doesnt give a sepereate one for ring lands. i would just add it into the deck volume.
turbo hogster
Member #: 178
stowmaket suffolk
easiets way is to get some glass and vasoline and measure using syringe i would say that would be around the 10-12cc markish
fordimus maximus
Member #: 1357
telford,shropshire
thanks guys, the calculator im using does have the separate box for ring lands so ive just added the 3.57 in.
thanks again
