Home > Wanted > mambas and non servo pedal box :)
jamz
Member #: 2292
Tool
Herne Bay, kent
both of those please :)
a set of mambas in any condition and a non servo pedal box
cant beat a good blowout.
gregh55
Member #: 3636
herefordshire
hi, my old chap has some 6x10 mambas forsale. . . .
jamz
Member #: 2292
Tool
Herne Bay, kent
how much and does he have center caps?
gregh55
Member #: 3636
herefordshire
yes it has the centre caps but there a bit errrm crap! lol as for price £150ono
Alex1340
Member #: 111
Loughborough
Why a non servo pedal box? The brake pedal is the only differnt due to the arm from the pedal to the brake servo master cylinder. Take you pedal off drill the rivit out and attch the older style brake master cylinder. Bob is your perverted uncle.
jamz
Member #: 2292
Tool
Herne Bay, kent
i was told i need a non servo pedal box... i dont understadn what you mean... tbh i dont really no much about it
jamz
Member #: 2292
Tool
Herne Bay, kent
and thats a little more than i wanted to pay for a set with out caps
im going to be getting them poadercoated orange anyway soo condition isnt to much of an issue
Alex1340
Member #: 111
Loughborough
right the brake pedal for a servo has a rod attached to the pedal which goes up and in to the engine bay and connects to the servo cylinder. The Non servo master cylinder has it's own rod built in which goes from the engine bay in to the cab and fixes to the pedal. If you take the rod off your servo pedal you can then fit the non servoMaster cylinder to you pedal.
jamz
Member #: 2292
Tool
Herne Bay, kent
ok is it that easy?... do peopel do that all the time then?
Mr Joshua
Member #: 1954
Luton Bedfordshire
From my experience of rover design they would not have changed the design of the pedal box so the whole size for the pin will be the same. |So from my humble experience yes it should be that simple.
Own the day
jamz
Member #: 2292
Tool
Herne Bay, kent
well i need a new pedal box anyway as i had to cut my old one to get it out :)
so any pedal box, master cyclinders and some mambas wanted :)
jamz
Member #: 2292
Tool
Herne Bay, kent
anyone?
jamz
Member #: 2292
Tool
Herne Bay, kent
ok i really need this now... help!!!!
