Home > General Chat > Head Gasket Failure ....
My compressor - low "mileage", you can still see the honing marks in the bores. It's actually 7 years old and has had a lot of use but the gasket is crap, plain CAF, no reinforcing yet it is subject to 10 bar.
Machine Mart wanted ~£25 for a complete set of gaskets then I discovered Clarke have a direct sale outlet for parts, still had to order the whole set but ~£12 !!!
Best bit was when I was dragging the compressor out of where it was trapped in the corner of the garage.....
The receiver still had 3bar of air inside - it woke the neighbours.....
WOOOOOSSHHHHHHHH!!!
That's nice to se some thing a little different, was thinking i'd see a mini head gasket, It's good you can get the spares *happy*
We use CAF substitue head gaskets with no re inforcement on some of our refrigeration compressors and they see 18 bar when operating and 28 bar on the odd ocassion. Nothing wrong with CAF gaskets, other than the asbestos content if it is indeed true CAF
Edited by Sprocket on 1st May, 2009.
Send the head off to Benross *wink* hell lower the CR lol
Fair point Sprocket but it also depends on the design...
It will be CAF substitute, I just use the old term because.... , well I am old!
In this case the gasket is quite thick (0.8mm) and the "land" where it failed very narrow, and no bolting in that location. Overall bad design
My cynicism comes from in my industry (power generation) we went away from plain CAF in favour of metaflex for anything but very low pressures ages ago. Mind you, we have serious temperature to deal with as well.
PaulH
Member #: 2340
Dublin Ireland
Ah you fitted the big bore head I see rod what with the pockets and all lol
On 17th Feb, 2009 Rob H said:
I see the last thing you sprayed was red then LOL
No !!!
But your logic is sound - Last thing I sprayed in celly was red but when I started using 2K, I ducted the suction filter to a "vent" outside the garage so I could use the compressor for breathing air too (air fed mask).
So that red is about 5-6 years old....
But it does show how crap the air filter on the compressor is :)
