| Home > Help Needed / General Tech Chat > flywheel to crank stepped locking washer and duplex oil shim | |||||||
1st May, 2009 at 10:53:37pm
hi, its been a while since iv worked on the turbo project. the engine is a 1275 a+
2nd May, 2009 at 10:38:15am
1st question - can't remember
Edited by Rod S on 2nd May, 2009. Schrödinger's cat - so which one am I ??? |
2nd May, 2009 at 12:40:15pm
Strip it and put the oil trow ring in or you will have a lovely oil patch on your drive untill you do I know I tryed one with out once bad Idea,
On 17th Feb, 2009 Rob H said:
2nd May, 2009 at 05:39:34pm
hi, thanks for the replys. established that they are different, stripped the clutch off another engine. also added the oil throw ring in. cheers |
