Home > Help Needed / General Tech Chat > Davies Craig Water Pumps
Simon
Member #: 1865
Norwich, Norfolk
Has anyone got a how-to guide for fitting one of these?
What happens with the old water pump, does that get left but blanked off, do you remove it and put some kind of blanking plate in place, or does this type of leecy pump fit in the place of the old mechanical one?
http://cgi.ebay.co.uk/DAVIES-CRAIG-ELECTRI...p3286.m63.l1177
Mr Mini
Member #: 346
Portsmouth
ZeroT
Persoanlly im going to fit this plate:
http://www.shengineering.co.uk/pcmwaterpumpplate.aspx
and run an electric pump between the bottom radiator outlet and this plate inlet.
1310cc TWINK - T Conversion
This is what I did when I had a leccy pump.
On the first one I was using a front mounted rad, so everything was removed and an insert pressed in to block the hole. On the second one I was using the side rad & still wanted to retain the fan, so just the impellar was machined off.
Simon
Member #: 1865
Norwich, Norfolk
On 3rd May, 2009 Mr Mini said:
ZeroT
ooo now thats nice.
its just the design of the davies one looks like it bolts in place of the old one.
can ROB1N comment as I see he has one fitted
hario
Member #: 2885
Thing is with retaining the waterpump for the fan and as an idler pulley for the alt. belt, you will still experience w/pump seal failure. Which means you still have to periodically replace the shittin thing even though you have electrical goodness moving your coolant!
