Home > Help Needed / General Tech Chat > Door Rubbers
Tweaked
Member #: 2873
Hi all, ok my mini has been deseamed and because it used to be in SA there wasnt a prob with water leaking in, so i want to know if anybody knows of a place that can make up door rubbers in the milton keynes area or suggest a nice thick rubber that could work?
Thanks in advance
Cheyne
Ive known people to use an upside down T shaped rubber bonded onto the window frame as a secondary seal
Paul
Tweaked
Member #: 2873
Thats not a bad idea cheers for that paul
Paul
I would have thought standard new seals will be fine as they will not have moulded like the original ones
Tweaked
Member #: 2873
I've tried a new set before and they didn't work, maybe i should have a go with a new set with a rubber on the window frame.
