Home > General Chat > Front Coilover Spring Weight
BadgerBaiter
Member #: 2257
Brighton
Does any one know a suggested spring weight for a mini running an A series turbo engine with a carbon front end?
I have searched high and low and can't find anything to do with a front end weight (at least with an A series) and only really coming up with stuff for the rear end.
Any help would be greatly appreciated.
Thanks.
http://www.jolyonway.com
if you want a bit of compliance I'd say start on 200lbs, at the length to fit your dampers fully open,
carl
BadgerBaiter
Member #: 2257
Brighton
Many thanks for you help :)
Hopefully ordering a set of Gaz coilovers later on today.
Miglia's are often around 220kgs on the front corners if that helps
edit: can't spell
Edited by Jimster on 6th May, 2009.
