Home > General Chat > the hog now sorted i hope
turbo hogster
Member #: 178
stowmaket suffolk
well after fixing the bloody oil leak ( i hope) which was down to the half moon oil seal had slipped round a bit leaving a 2mm hole so i claened it up and just filled with silicon, because be buggered if i am going to split a engine just for that.
new throttle cable so it doesnt stick any more
new clutch, but did find the problem there which is a bit more tricky
front bush is to worn now on the jk primary gear so i need a new set.
well to be truefull they are years old a i got them of miniwilliams and they were abused then so cant grumble.
so i sagrifised another clutch plate and i will see how long it lasts, hopefully it will hold out untill winter as she is due a strip down so i will do it then
it only slipped before when i realey gunned it som should be ok.
took her out for a test drive and blloy hell she went well on 18psi i forgot how well afr was reading 12.4 on full chat so thats ok.
just got new headlight bowls now and all jobs are done
keeps you busy hoggy, onwards and upwards
T3Tone
Member #: 252
Sunny suffolk
Nice one buddy, hope she behaves now.
Mine got another years MOT today, took the tester up the road - he was surprised *wink*
so its smiles all round then:)
-MINI CLUBMAN 1380 TURBO-
Nice to hear it's going well mate, 18 psi bloody hell mate, be careful!
