| Home > Help Needed / General Tech Chat > First time oil pressure | |||||||
7th May, 2009 at 04:15:29pm
Well im pretty excited!
Edited by richminiturbo. on 11th May, 2009. |
7th May, 2009 at 04:20:32pm
Thats sounds fine
Edited by minimole23 on 7th May, 2009. On 7th Oct, 2010 5haneJ said:
7th May, 2009 at 04:51:58pm
Hehe, nice one fella, yeah that sounds spot kidder, my drops between 35 and 40 when hot, although mine does run very hot due to the timing! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
7th May, 2009 at 05:16:06pm
Good gooood!
7th May, 2009 at 05:18:49pm
As above sounds fine. Good that you cranked it with the plugs out, gives the starter and battery an easier life. Own the day
7th May, 2009 at 05:38:53pm
Good news. Feels great eh!
In the 13's at last!.. Just |
7th May, 2009 at 06:45:51pm
Thanks mate!
7th May, 2009 at 06:51:57pm
indeed! good luck,
7th May, 2009 at 07:09:31pm
Oki doki I will do!
7th May, 2009 at 07:40:56pm
i've not found a spring that comes with the ball to be any where near short enough yet,
7th May, 2009 at 08:14:10pm
I juiced up the battery and it spun alot faster with the plugs out!
Edited by richminiturbo. on 7th May, 2009. |
7th May, 2009 at 08:22:10pm
Fuck, just realised I paid £64 for that oil feed pipe. |
7th May, 2009 at 08:32:17pm
shit luck monsieur!
7th May, 2009 at 08:32:39pm
f'fing hate jump leads!! "Turbo's make torque, and torque makes fun"
7th May, 2009 at 08:35:43pm
DOH!!
7th May, 2009 at 08:44:23pm
As long as the engine got progressively tigher when building it, when adding pistons that that seems pretty normal for a fresh build. as long as it didn't lock up or anything. On 7th Oct, 2010 5haneJ said:
7th May, 2009 at 08:55:02pm
Was pretty gutted when it happend, thought it just burnt the outer braid a smidge then saw oil weeping out..
7th May, 2009 at 09:38:28pm
i was thinking make a whole new hose, but depending how much hose is spare you could hack into it and add a joint,
7th May, 2009 at 09:40:42pm
cut the hose and measure the bore (its fucked anyway) and i'll compare it to the hose i have. On 28th Aug, 2011 Kean said:
7th May, 2009 at 09:50:17pm
Brilliant thanks alot!!
7th May, 2009 at 10:07:07pm
yep, similar to a garden hose, there a 3 parts, the outer nut, a sleve that goes between the braid and the hose inner, and the main body that slides up the hose inner.
7th May, 2009 at 10:16:23pm
Sounds simple enough!!
7th May, 2009 at 10:31:50pm
i love them fittings, used quite a few now for brakes ,oil and fuel.
8th May, 2009 at 02:32:23pm
Went down to my local hose specialists and came out with this:
Edited by richminiturbo. on 8th May, 2009. |
8th May, 2009 at 02:34:55pm
Dont forget the videos! If something is worth doing, it's worth doing half of. |
