Home > Wanted > o/t long shot - midget caliper/s
nutter driver
Member #: 47
Not very sunny swanage
bit of a long shot, but i know a few of you are parts hoarders or run them as second cars!!!
Im in need of either a n/s caliper or preferably a pair of calipers from a midget to rebuild to use on my daily driver of the moment, (actually a A35 - its great!!!)
Anyone got any kicking around?? quite happy to get ones in need of a refurb......
cheers peeps,
Pete
Whilst at it, could you please measure the distance between the caliper mount holes?
Having a ADO16 project you see.. :)
Pete,
I have a new passenger side one, on idea why, if you want it make me an offer and it's yours.
The Lockheed part no is: 3243222C
Rob
tadge44
Member #: 2500
Buckinghamshire
Vegard - the centre to centre distance is 3.25 inches.
You have reminded me that the old 1100/1300 range used the same calipers and I used to be able to find them in scrapyards,but not any more !!.
Aha, so that's where the link is. I'm dying to find something that can make me throw the swinging calipers in the bin.
How does the Midget caliper compare to the Mini 8,4" one?
Midget ones taste sweeter and are more succulent.
If my memory serves me correct the pistons are slightly bigger than the 8.4 ones, and the castings have a bit more meat on them. If you want I'll get you a couple of photos, unfortunately none of my cars have 8.4" Mini brakes so I can't do any comparison shots.
It does sound as the early 1100/1300 calipers might be better than the later ones..
If it helps the pistons are a smidgen under 2" diameter
nutter driver
Member #: 47
rob h, pm heading your way, thankyou!!
V, the pistons in these are exactly the same as in the 8.4" mini brakes, as are the seal kits for the pistons!!
Hmm what was the reason for going from Twin pots to the awful swinging calipers then??
Cost?
obviously pad knockback lol
Cost?
nutter driver
Member #: 47
still need one if anyone has one or a pair?!?!
cheers,
Pete
http://cgi.ebay.co.uk/MG-MIDGET-HEALEY-SPR...%3A1%7C294%3A50
if its of any use , i have a couple of full corners off a wolsely 1100 ,hub, disc caliper ,cv,etc , both sides ,pretty dam rusty from the scrap yard ,50 quid the pair ?
