| Home > Help Needed / General Tech Chat > Tomcat turbo ? | |||||||
141 Posts Member #: 2408 Advanced Member surrey / ewell area. |
11th May, 2009 at 11:57:13am
Hi all just received a t25 with the internal dump valve on inlet housing would this be a tomcat turbo?, it has a .48 a/r cant tell what the exhaust side is. I havent got round to measuring it yet but its smaller... maybe .42? And has the standard crack around wastegate! Not to worried though as it is pretty small and doesnt run very far.P.s do u have to run the water pipes ? |
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
11th May, 2009 at 12:16:10pm
no but i think there's a trick with the internal actuator/dump valve, to fill it up with washers instead of the spring.....I beleive this enables you to adjust the boost even more. i think? "Cars are a lifetime of pain" |
11th May, 2009 at 12:22:56pm
What's a tomcat turbo ?
11th May, 2009 at 12:46:21pm
Rover tomcat- i think it is the 220 turbo coupe 93/95 something like that |
11th May, 2009 at 01:02:06pm
You don't have to run the water pipes plumbed in, but if the rest of your cooling system can cope, then it's beneficial for the Turbo. |
11th May, 2009 at 01:17:09pm
Cool cheers Phil well ive got a twin core minispares jobbie which seems to do the trick ata the mo. What do u reckon about the turbo ? fairly suitable? Any luck with your pillar drill yet? |
11th May, 2009 at 01:20:55pm
Those turbos work pretty well as I recall. I believe Dan ran one and was running low 14's with a pretty heavy car. On 17th Nov, 2014 Tom Fenton said:
![]() 465 Posts Member #: 1972 Senior Member Worcester |
11th May, 2009 at 05:04:41pm
would be .49 on exhaust housing for a tomcat t25 |
11th May, 2009 at 07:35:30pm
i ran one on my k. made 197hp and 170ft/lb at 1 bar. above that it was becoming less efficient. the great thing about these turbo's is an upgrade to a larger T25 or anything from the t/GT28 family are a bolt on upgrade. lots of choice out there. turbo 16v k-series 11.9@118.9 :)
11th May, 2009 at 09:09:59pm
I think Ian runs one of these no? I think with a mirage setup you need to change the comp housing for one without the dump valve as it won't fit between the bulkhead and block. On 7th Nov, 2008 Nic said:
12th May, 2009 at 05:52:30pm
Yeah i figured i might have to but not to much of a problem cheers Jay |
