| Home > For Sale > Oil Jets | |||||||
549 Posts Member #: 5327 Post Whore Dudley, West mids |
11th May, 2009 at 09:07:45pm
Hi folks. Thought I'd put these on here before ebay. They are a set of 4 under piston cooling jets. Made out of aluminium they are of very good quality. I did want to fit them to my engine but fitting them looked to complicated for myself as I don't own the correct machines to carry out the mod. I even took them to an engine centre and asked about getting them fitted and I think what I asked them to do scared them (to much work involved). Anyways I'm looking around the £40 mark I paid around £50 about 7 months ago. Edited by madcatminis on 11th May, 2009. |
11th May, 2009 at 10:59:15pm
what are they off ? Edited by BENROSS on 11th May, 2009.
12th May, 2009 at 07:23:06pm
They are not off a perticular car as they are a custom item. They where brought off ebay with the discription 'mini turbo oil jets'. The seller was selling a few sets of these as well as some which looked like a bent piece of tubing. come to think of it the cheaper ones would have been easy to fit. I brought these as the quality is ace. I'd find them hard to fit as there doesn't look like enough room between cylinder 3 and 4 to mount them. the dizzy shaft casting bit gets in the way (if thet makes sense). I suppose if you where using megajolt you could machine this bit away to make a good flat surface. :) |
12th May, 2009 at 07:59:53pm
They look well made, but I very much doubt that they can be fitted in the A series block, even if you machine off the dizzy boss.
Edited by Paul S on 12th May, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
12th May, 2009 at 08:20:21pm
Wow paul thats some good machining. You are bang on right mate, I doubt they would fit the a series by the looks of your block. Think I've been robbed. :) |
