| Home > Help Needed / General Tech Chat > Still Getting Hot..! | |||||||
784 Posts Member #: 912 Post Whore North Yorkshire |
12th May, 2009 at 07:52:41pm
Right Gents,
Edited by Si P on 16th Jun, 2009. I drill holes in everything..! |
![]() 367 Posts Member #: 1643 Senior Member West London |
12th May, 2009 at 07:57:43pm
Sorry off topic, but wont that filter suck in water :S Lightweight racer coming soon. |
12th May, 2009 at 08:03:33pm
Yes, and sticks and birds and kids holding hands.
Edited by Si P on 12th May, 2009. I drill holes in everything..! |
12th May, 2009 at 08:17:00pm
On 12th May, 2009 Si P said:
Yes, and sticks and birds and kids holding hands. Si On 28th Aug, 2011 Kean said:
12th May, 2009 at 09:07:48pm
I think it just pulls water from the bottom hose and it rises up the heater pipe on its way to the pump, is it spinning the correct way? it could be pumping it toward the bottom hose hence your overheating problem 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
12th May, 2009 at 09:29:17pm
I've just taken the dog out for a walk, and the fresh air has cleared my retarded mind.
12th May, 2009 at 09:33:49pm
I think i'll go and buy a dog 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
12th May, 2009 at 10:29:24pm
Lovely looking car, good luck withy the water pump sounds like you've sussed it.
12th May, 2009 at 10:35:03pm
Yup, it's in Vizard's book. Better get a duct around that filter! On 13th Jul, 2012 Ben H said:
13th May, 2009 at 07:17:14am
On 12th May, 2009 Vegard said:
Yup, it's in Vizard's book. Better get a duct around that filter! it may lose a couple of bhp as you say but it looks the dogs dangly bits and might look a bit pony with a duct |
13th May, 2009 at 07:18:21am
Yes your right guys. One is in the pipeline. I think its at about 70+ mph that the air starts to take an affect.
On 12th May, 2009 wil_h said:
Lovely looking car, good luck withy the water pump sounds like you've sussed it. I read years ago that putting the filter in the position you have it is detrimental to power as the air races through it at speed. I drill holes in everything..! |
13th May, 2009 at 10:44:54am
Is that engine steady home made? |
13th May, 2009 at 02:04:24pm
Yes. and I have the patent for it. I drill holes in everything..! |
13th May, 2009 at 05:35:57pm
Yep I've seen what you done need a wider shot of your engine bay to confirm. Own the day
14th May, 2009 at 08:17:35am
also chuck away the thermo sleeve and fit a 74 deg thermo in, as this helps reglate flow through the rad, with just a sleev the flow through the rad is to quick hence eventually she will over heat always looking for them bigger bunches of bannanas |
14th May, 2009 at 11:32:17am
I'm wiring in a voltage regulator so I can control the flow rate. E.g. slow it down. And will eventually stick a thermister on to it so it can be an active controller.
On 14th May, 2009 turbo hogster said:
also chuck away the thermo sleeve and fit a 74 deg thermo in, as this helps reglate flow through the rad, with just a sleev the flow through the rad is to quick hence eventually she will over heat I drill holes in everything..! |
16th Jun, 2009 at 02:21:46pm
It's still getting really hot.... Edited by Si P on 16th Jun, 2009. I drill holes in everything..! |
16th Jun, 2009 at 02:39:35pm
Yup, it's in Vizard's book. Better get a duct around that filter! it may lose a couple of bhp as you say but it looks the dogs dangly bits and might look a bit pony with a duct If a person is more interested in go than show, I guess why not.. Gaylords! On 13th Jul, 2012 Ben H said:
16th Jun, 2009 at 02:39:57pm
16th Jun, 2009 at 03:17:38pm
Do you mean show than go, not go than show, V?
16th Jun, 2009 at 03:26:26pm
Water is defiantly pump through the systems. I have the burns to prove it.
16th Jun, 2009 at 04:12:24pm
Have you checked the timing with a timing light? In the 13's at last!.. Just |
16th Jun, 2009 at 04:32:40pm
Head gasket ? Was it a dodgy BK450 ?. |
16th Jun, 2009 at 06:29:38pm
Timing seems bob on.
16th Jun, 2009 at 07:46:08pm
Well I'm stumped now.
