| Home > Help Needed / General Tech Chat > Will i have to remove my SU? running issue?? | |||||||
11 Posts Member #: 6094 Member Boston |
13th May, 2009 at 04:01:05am
new to this site and still unfamiliar with the SU.
13th May, 2009 at 07:24:39am
as the choke move the jet down so making it run richer i would have thought about adjusting the mixture. what SU do you have? |
13th May, 2009 at 04:25:19pm
Hmmm. Im pretty sure its the standard metro turbo SU |
13th May, 2009 at 05:08:38pm
On 13th May, 2009 turboturd said: Sounds very lean
Hmmm. Im pretty sure its the standard metro turbo SU Own the day
13th May, 2009 at 05:51:17pm
its too way lean richen the mixture up by screwing in the mixture screw try a full turn in
13th May, 2009 at 05:52:15pm
how do i move the jet down while im choking? Like i said im pretty new to the SU. Forgive my ignorance. |
13th May, 2009 at 05:54:48pm
heres the spec
13th May, 2009 at 05:59:46pm
ATF fluid is too thin in my experience, thinner oil in the dashpot will put in less fuel when you accellerate (contarary to popular belief)
13th May, 2009 at 06:33:28pm
maybe check the lean off pipe for cracks |
13th May, 2009 at 06:49:31pm
k i will do all these recomendations tonight and get back to you guys. Thanks a ton for the suggestions. I really dont want to have to tear down the carb.
14th May, 2009 at 06:09:15pm
still no luck :(
15th May, 2009 at 04:36:24am
Get a wideband... Trying to diagnose this by description is not easy. On 17th Nov, 2014 Tom Fenton said:
15th May, 2009 at 08:53:08am
On 14th May, 2009 turboturd said:
still no luck :( no one has su rebuild kits for the turbo in the US either :( On 11th Feb, 2015 robert said:
15th May, 2009 at 06:39:44pm
On 15th May, 2009 apbellamy said:
TurboPhil sells them in the UK, he might we able to ship you one accross. http://www.turbo-mini.com/66091/63768.html On 14th May, 2009 turboturd said: still no luck :( no one has su rebuild kits for the turbo in the US either :( Sure can, I've sent a few to the US in the past. :) |
16th May, 2009 at 04:41:54am
Hey phil get me a quote on the kit and shipping to the US zip code of 01752.
18th May, 2009 at 12:55:33pm
Have you checked you've got the correct fuel pressure? Static it should be at 3.5 PSI, then rise with boost to stay 3.5 PSI above boost pressure. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
30th Sep, 2009 at 12:50:15am
this thing still wont run correctly :( im at wits end rebuilt the carb. Ordering another kit from phil to see if the seals he has are different. Im at my whits end. Luckily an Englishman I work with has come over and we diagnosed that the car was leaking air. Rebuilt it and it still runs like crap. |
30th Sep, 2009 at 08:27:06am
Have you checked your fuel pressure? This is quite important.
30th Sep, 2009 at 12:10:56pm
On 13th May, 2009 mini13 said:
ATF fluid is too thin in my experience, thinner oil in the dashpot will put in less fuel when you accellerate (contarary to popular belief) put some 20w 50 in there and see what its like. joe, i might have been falling into this trap? my std'ish road mini goes temprarily very rich when i floor it, hesitates, then pulls strongly again and the afr's steady out at about 12 i thought maybe the dashpot was flying up, stalling the inlet gases, and throwing too much fuel in? ive been trying thicker oil (on 60wt now), and its not made a jot of difference? also tried 2 springs, but now i think im strangling it? how does less dampning, i.e. thinner oil give less fuel? "Turbo's make torque, and torque makes fun"
30th Sep, 2009 at 01:28:07pm
joey my understanding is ( i may be a little out)
Edited by Brett on 30th Sep, 2009. Yes i moved to the darkside |
