Home > Wanted > Rear Subframe
adam1330
Member #: 238
essex
In need of a good rear subframe, anyone?
lockfast
Member #: 2775
Aberdeen
I ahve one that is good structurally but has some bolts broken off for mounting the radius arms plates. Nothing that wouldnt drill and tap though. Open to offers if you dont get any bette offers
adam1330
Member #: 238
essex
will keep it in mind, although postage will be a lot!
lockfast
Member #: 2775
Aberdeen
check out parcel2go.com you might get a surprise! cheaper than using the companies direct. Its here if you need it.
BadgerBaiter
Member #: 2257
Brighton
I am just about to drop my rear subframe off of my Mini. I shall let you know if it looks ok.
I am down in Brighton, so if you are coming down on Sunday, would save postage. . .
http://www.jolyonway.com
adam1330
Member #: 238
essex
still after one, near essex would be ideal.
