Home > Help Needed / General Tech Chat > my mini hits boost guage reads 5psi then cuts out. possible fuel problem.
psimini
Member #: 6070
it feels like its running out of fuel. does this need work around carb jet and needle area or fuel pressure...
na engine + turbo + boost = ya hewwww
evolotion
Member #: 83
Glasgow, Scotland
as i already said in one o your other threads:
do you have the restrictor as found in the standard inlet? this is very important, few threads around about it, including a novel solution to get around teh restrictor involving a pitot-static tube.
Denis O'Brien.
