Home > Introduce Yourself > hello
turbonics
Member #: 6137
hello i have a 1995 rover mini currently turning it in to a mini turbo but i have came to a little problem the diff i was going to use in the engine is the wrong size and i am looking for just a standard diff thanks reading any one who can help *happy*
steve w
Member #: 1917
AKA chargedzetec
take a breath
welcome
use the search button!
What do you mean by wrong size ???
Wrong ratio perhaps, but what do you want, ie what wheel size are you using, what RPM per MPH do you want, etc ???
There is a big difference between people who want fast acceleration but low top speed and others who compromise acceleration but have higher top speeds and lower noise and engine wear.
But, as said, it's all there with the Search Button.
Welcome anyway.....
Hello
Welcome to TM.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Welcome.
Sounds like your going down a very specific route with your car, or has someone given you a box of bits and the crown and pinion wheel are not of compatible size's?
Own the day
jakelloyd99
Member #: 5310
Oxford/Hertford
hey
