Home > For Sale > A+ block
tadge44
Member #: 2500
Buckinghamshire
This is an Ital block, but I understand that a mini crankshaft will fit.
It is stripped bare, oil gallery plugs out, thoroughly cleaned and does have the main bearing caps.
It is on 20 thou over and really needs reboring again.
Could be the ideal start to a 1380 motor, allowing all the boring to be done before you strip your own engine and rebuild on the fresh block.
Looking for £40, and it will need to be collected from South Bucks.
tadge44
Member #: 2500
Buckinghamshire
Ignore this, I am a prat and have double posted -sorry.
