| Home > General Chat > Lose the front bumper? | |||||||
928 Posts Member #: 65 Post Whore South Yorkshire |
20th May, 2009 at 12:32:58pm
The rear bumpers on my car are knackered and I'm not going to bother replacing them as it means cutting up a pair of estate bumpers.
20th May, 2009 at 12:36:03pm
I don't have them on mine. I tried a set on, but didn't like the way the back end looked.
Edited by theoneeyedlizard on 20th May, 2009. In the 13's at last!.. Just |
20th May, 2009 at 12:37:59pm
Ni pic's, but the look OK if you remove the mounting lip from the front panel. On 11th Feb, 2015 robert said:
20th May, 2009 at 12:45:32pm
My old Mini (ages ago) was without front and rear and that's what I'm doing again.
20th May, 2009 at 12:56:23pm
i've looked at this thread three times and only just notice the fooking filters sticking out the front!
20th May, 2009 at 12:56:48pm
I would remove the bumper lip. The car is stripped at the moment and I'm liking the uncluttered look at the rear. |
20th May, 2009 at 01:00:27pm
On 20th May, 2009 Rod S said:
My old Mini (ages ago) was without front and rear and that's what I'm doing again. Leaving the lip (mounting flange) on without a bumper could technically get you nicked under the Construction and Uses Regulations if you are pulled by a zealous Cop. (sharp edge to slice pedestrian's legs off)..... I was aware of this, so to minimise the chances of the above happening, I've run a strip of sill trim along all the edges. I hope this is enough to keep the pesky old bill at bay. In the 13's at last!.. Just |
20th May, 2009 at 08:02:58pm
No leave it - you'd spoil it On 5th Sep, 2011 Vegard said:
15 Posts Member #: 6098 Member frome |
21st May, 2009 at 05:44:53pm
The Panther |
